WilsonY's avatar
WilsonY
Tutor
Mar 02, 2022
Nighthawk R7000 firmware update with APP & Connected Question
So I had upgraded my Comcast internet speed to 800mbs about a year ago and upgraded my modem and router to be able to run at Gig speed.   For the past year since the upgrade, my internet speed have ony reached about 250mbs at best, and I had always thought it was the Provider's fault.  I finally had a tech come out today and based on his diagnosis, the speed coming out of the modem is 1gb, so that leaves him to conclude that the issue is with the router.  He suggested that I check to see if there is  a new firmware update, which, there indeed is.  Here comes the problem though...
I used the Nighthawk app to check for updates and it says "no new firmware is available at this time".   But when I look at what firmware version it is currently running on, it says v1.0.11."126".  According to Netgear website, the newest firmware is version ..."134".  After reading the manual, it seems like I'll have to do Manual Update....  So my problem now is that none of my laptops have any Ethernet Ports.  Hoping someone can give me some advice here.  I'm a novice when it comes to tech, so hoping there is a simple way of doing this.  Thanks in advance.
