Xino
Oct 21, 2017Tutor
nighthawk R7000 firmware V1.0.9.12_1.2.23 update wifi problems
i have a problem with my wifi after updating firmware to V1.0.9.12_1.2.23. after i updated i got less then half the download speed on my wifi now. anyone got the same problem, and how do i fix it ?...
- Nov 21, 2017This is the reply from the helpdesk from yesterday : Hello,
Thank you for contacting Netgear Support.
Unfortunately our developers do not announce the release dates of upcoming firmware, so I am unable to supply you with that information.
You have indicated that there are problems with the router performance since you updated the firmware. In such a case, it is possible to downgrade the firmware, until a new version of the firmware is released that addresses the problems of the earlier version.
To downgrade your firmware, please follow these steps :
1) Go to this link to download the firmware version 1.0.9.10. (Current version is 1.0.9.12)
https://kb.netgear.com/000049003/R7000-Firmware-Version-1-0-9-10
->Save this file, and extract the zip into a folder, e.g. on your desktop
2) Connect an Ethernet cable to your router and a laptop / PC
3) Open a browser and go to this address : routerlogin.net
4) Enter the password that you chose during the router setup. If you did not change it, it will be ‘password’
5) When you see the menu, go to Advanced -> Administration -> Router Update
6) Click on Browse and choose the folder where you unpacked the zip file, then choose the .chk file.
7) Click on Upload and wait for the installation to complete.
I hope this will help you with the performance problem of your router.
I look forward to hearing from you.
Please note that if you prefer to communicate in Dutch just reply to this case in Dutch.
Have a great day,
Kind regards
Joeri
Netgear Level 1 Technical Support
http://support.netgear.com
ak988
Nov 18, 2017Aspirant
There are issues with EVERY firmware update. I am looking at other vendors for internal connecivity. Then put a DD-WRT build with VPN on the netgear.
Fer2017
Nov 19, 2017Aspirant
Or advanced tomato, seems like a nice layout, latest firmware update from November.
- Fer2017Nov 21, 2017AspirantThis is the reply from the helpdesk from yesterday : Hello,
Have a great day,
Kind regards
Joeri
http://support.netgear.com- juchedNov 22, 2017Apprentice
So, did you downgrade? Did it work better? Does 1.0.9.10 have Disney circle?
