Xino
Oct 21, 2017Tutor
nighthawk R7000 firmware V1.0.9.12_1.2.23 update wifi problems
i have a problem with my wifi after updating firmware to V1.0.9.12_1.2.23. after i updated i got less then half the download speed on my wifi now. anyone got the same problem, and how do i fix it ?...
- Nov 21, 2017This is the reply from the helpdesk from yesterday : Hello,
Thank you for contacting Netgear Support.
Unfortunately our developers do not announce the release dates of upcoming firmware, so I am unable to supply you with that information.
You have indicated that there are problems with the router performance since you updated the firmware. In such a case, it is possible to downgrade the firmware, until a new version of the firmware is released that addresses the problems of the earlier version.
To downgrade your firmware, please follow these steps :
1) Go to this link to download the firmware version 1.0.9.10. (Current version is 1.0.9.12)
https://kb.netgear.com/000049003/R7000-Firmware-Version-1-0-9-10
->Save this file, and extract the zip into a folder, e.g. on your desktop
2) Connect an Ethernet cable to your router and a laptop / PC
3) Open a browser and go to this address : routerlogin.net
4) Enter the password that you chose during the router setup. If you did not change it, it will be ‘password’
5) When you see the menu, go to Advanced -> Administration -> Router Update
6) Click on Browse and choose the folder where you unpacked the zip file, then choose the .chk file.
7) Click on Upload and wait for the installation to complete.
I hope this will help you with the performance problem of your router.
I look forward to hearing from you.
Please note that if you prefer to communicate in Dutch just reply to this case in Dutch.
Have a great day,
Kind regards
Joeri
Netgear Level 1 Technical Support
http://support.netgear.com
samman
Nov 29, 2017Tutor
Is this firmware still broken?
tulong
Nov 29, 2017Guide
Sure is. Netgear has not released a fix for it yet and I don't foresee it anytime soon. This will be the last Netgear I buy for sure.
- bryrpNov 29, 2017Guide
Chiming in - unfortunately I have a 1week old baby so this is completely unacceptable. Our baby minotor, nest protect, nest security cam's, window monitor, door monitors, etc.... all rely on our wireless connectivity.
Devices will randomly lose network access and cannot reconnect until I reboot the router. The wireless will work for 24 hours before I have to reboot again. For now I will downgrade to R7000-V1.0.9.10_1.2.21 - but please fix as this is unacceptable and at this point in time a safety failure for my newborn.
