Xino
Oct 21, 2017Tutor
nighthawk R7000 firmware V1.0.9.12_1.2.23 update wifi problems
i have a problem with my wifi after updating firmware to V1.0.9.12_1.2.23. after i updated i got less then half the download speed on my wifi now. anyone got the same problem, and how do i fix it ?...
- Nov 21, 2017This is the reply from the helpdesk from yesterday : Hello,
Thank you for contacting Netgear Support.
Unfortunately our developers do not announce the release dates of upcoming firmware, so I am unable to supply you with that information.
You have indicated that there are problems with the router performance since you updated the firmware. In such a case, it is possible to downgrade the firmware, until a new version of the firmware is released that addresses the problems of the earlier version.
To downgrade your firmware, please follow these steps :
1) Go to this link to download the firmware version 1.0.9.10. (Current version is 1.0.9.12)
https://kb.netgear.com/000049003/R7000-Firmware-Version-1-0-9-10
->Save this file, and extract the zip into a folder, e.g. on your desktop
2) Connect an Ethernet cable to your router and a laptop / PC
3) Open a browser and go to this address : routerlogin.net
4) Enter the password that you chose during the router setup. If you did not change it, it will be ‘password’
5) When you see the menu, go to Advanced -> Administration -> Router Update
6) Click on Browse and choose the folder where you unpacked the zip file, then choose the .chk file.
7) Click on Upload and wait for the installation to complete.
I hope this will help you with the performance problem of your router.
I look forward to hearing from you.
Please note that if you prefer to communicate in Dutch just reply to this case in Dutch.
Have a great day,
Kind regards
Joeri
Netgear Level 1 Technical Support
http://support.netgear.com
dkjames
Nov 29, 2017Tutor
There is absolutely no reason why this fix hasn't been out weeks ago. Why is this taking so long to patch this? Are the engineers at Netgear so incompetent they can't figure out a solution to this issue? This is very bad business ethics. People buy your products based on your false claims of speed, reliability and security. This is what we get? This is unacceptable we've been patiently waiting for months. When can we expect to get a new update?
bryrp
Nov 29, 2017Guide
as an aside - can a MOD please change the thread title from [Solved] to [Work-around] - solved is bull**bleep**.
- bryrpNov 29, 2017Guide
"*bleep*" lol - got it, understood. For what it's worth my wireless just crapped the bed again and I am running R7000-V1.0.9.10_1.2.21
- HoytyNov 29, 2017Apprentice
bryrp wrote:My wireless just crapped the bed again and I am running R7000-V1.0.9.10_1.2.21
This is one problem I have never had with any version 1.0.9.6, 1.0.9.12 or newer beta. My R7000 and all devices on it have worked without fail for a month or more at a time. I am wondering if you or others that have reported this issue have some really bad behaving wi-fi device or maybe a really crowded wi-fi space? Anyone who has had issues like this have you tried running something like inSSIDer? Just to see what is going on channel wise? I found the Auto channel picker on R7000 (and most consumer Wi-Fi) to be pretty poor and everything seems to end up on channel 1.
- tulongNov 30, 2017GuideMine is the only one running on channel 11 (statically set) with full bars. I still have the problems even was sitting about 5ft away
- tulongNov 29, 2017Guide
I think may be it's time to file a complain with the federal consumer protection agency since the company does nothing, not even showing the willing, to fix the issue.
- Mr_DJNov 29, 2017Apprentice
First, my apologies if I understand you wrong, but it seems to me you "speed crawing" people are misunderstaning something, regarding the WPA2 security status of the different firmwares released.
Because ALL of the currently released firmware versions have same WPA2 vulnerability(but is only a security problem, if you use the Netgear router(s) in bridge mode). So, if you don't need a specific feature only available in the latest v1.0.9.12_xxx version, there really isn't any benefit to staying with the latest release, especially not if it far from give you the speed you pay for. So what I am saying is, don't feel like you need to stick to very latest release because of WPA2 security concearns, because this version has same issue as all of the older versions! Your welcome! ;-)
Read this info page about the WPA2 security issue = https://kb.netgear.com/000049498/Security-Advisory-for-WPA-2-Vulnerabilities-PSV-2017-2826-PSV-2017-2836-PSV-2017-2837
- tulongNov 29, 2017GuideI don't think that's accurate. Here is what the WPA2 crack look like based on what has been found:
The weakness Vanhoef identified is in the WPA2 protocol's so-called "four-way handshake." That procedure determines whether a USER attempting to join a network and the access point offering the network have matching credentials. It's essentially an exchange that ensures the user knows the network password.
Therefore, it doesn't matter if the wireless router is in routed mode or bride mode. As long as you are using WPA2 encryption method, you are affected
tulong wrote:I think may be it's time to file a complain with the federal consumer protection agency since the company does nothing, not even showing the willing, to fix the issue.
I am not going to say Netgear is awesome but I will tell you they are working on it. I have running currently a newer firmware. If you go back in this thread you can see my details on it. It isn't perfect yet but it is much better. I am working with support and hopefully soon engineering on troubleshooting remaining issues. Yes they released a bad firmware and yes it has been almost 2 months but they aren't ignoring issue they are just slow it seems.
- tulongNov 30, 2017GuideWell.... I'm glad to hear that they are working on it, but it's been at least two months and Netgear just keeps silence without either confirming nor denying the problem. That frustrates users. I hope they will release a fix soon. Thank you for letting us know.
