Xino
Oct 21, 2017Tutor
nighthawk R7000 firmware V1.0.9.12_1.2.23 update wifi problems
 i have a problem with my wifi after updating firmware to V1.0.9.12_1.2.23.  after i updated i got less then half the download speed on my wifi now.  anyone got the same problem, and how do i fix it ?...
- Nov 21, 2017This is the reply from the helpdesk from yesterday : Hello,
Thank you for contacting Netgear Support.
Unfortunately our developers do not announce the release dates of upcoming firmware, so I am unable to supply you with that information.
You have indicated that there are problems with the router performance since you updated the firmware. In such a case, it is possible to downgrade the firmware, until a new version of the firmware is released that addresses the problems of the earlier version.
To downgrade your firmware, please follow these steps :
1) Go to this link to download the firmware version 1.0.9.10. (Current version is 1.0.9.12)
https://kb.netgear.com/000049003/R7000-Firmware-Version-1-0-9-10
->Save this file, and extract the zip into a folder, e.g. on your desktop
2) Connect an Ethernet cable to your router and a laptop / PC
3) Open a browser and go to this address : routerlogin.net
4) Enter the password that you chose during the router setup. If you did not change it, it will be ‘password’
5) When you see the menu, go to Advanced -> Administration -> Router Update
6) Click on Browse and choose the folder where you unpacked the zip file, then choose the .chk file.
7) Click on Upload and wait for the installation to complete.
I hope this will help you with the performance problem of your router.
I look forward to hearing from you.
Please note that if you prefer to communicate in Dutch just reply to this case in Dutch.
Have a great day,
Kind regards
Joeri
Netgear Level 1 Technical Support
http://support.netgear.com
RV7000
Dec 01, 2017Aspirant
How can I get a copy of an older firmware ? Is there a search feature on the site?
- shamarinDec 01, 2017Virtuoso
There is allready available new version of firmware http://www.netgear.com/support/product/R7000#Firmware%20Version%201.0.9.14. And at the bottom of this page there is a link to previous builds. First try the new one.
- HoytyDec 01, 2017Apprentice
shamarin wrote:There is allready available new version of firmware http://www.netgear.com/support/product/R7000#Firmware%20Version%201.0.9.14. And at the bottom of this page there is a link to previous builds. First try the new one.
It was released earlier today, so not very old. Thanks for noticing and pointing it out though.
- tulongDec 01, 2017GuideHere is what I did:
1. Backed up my current config
2. Reset the router to manufacturer
3. Upgrade the firmware to version 1.0.9.14
4. Rebooted the router
5. Restored the config from backup
Here is the result:
1. The range has improved dramatically. Haven't experienced any drop yet
2. The speed is back to normal on Android, Windows and IOS devices (my iPhone and Ipads). This is the first time I get my upload/download full speed back
I'll keep monitoring to see if it's staying that way or not. So far, I'm very pleased with the new firmware release.
