Xino
Oct 21, 2017Tutor
nighthawk R7000 firmware V1.0.9.12_1.2.23 update wifi problems
i have a problem with my wifi after updating firmware to V1.0.9.12_1.2.23. after i updated i got less then half the download speed on my wifi now. anyone got the same problem, and how do i fix it ?...
- Nov 21, 2017This is the reply from the helpdesk from yesterday : Hello,
Thank you for contacting Netgear Support.
Unfortunately our developers do not announce the release dates of upcoming firmware, so I am unable to supply you with that information.
You have indicated that there are problems with the router performance since you updated the firmware. In such a case, it is possible to downgrade the firmware, until a new version of the firmware is released that addresses the problems of the earlier version.
To downgrade your firmware, please follow these steps :
1) Go to this link to download the firmware version 1.0.9.10. (Current version is 1.0.9.12)
https://kb.netgear.com/000049003/R7000-Firmware-Version-1-0-9-10
->Save this file, and extract the zip into a folder, e.g. on your desktop
2) Connect an Ethernet cable to your router and a laptop / PC
3) Open a browser and go to this address : routerlogin.net
4) Enter the password that you chose during the router setup. If you did not change it, it will be ‘password’
5) When you see the menu, go to Advanced -> Administration -> Router Update
6) Click on Browse and choose the folder where you unpacked the zip file, then choose the .chk file.
7) Click on Upload and wait for the installation to complete.
I hope this will help you with the performance problem of your router.
I look forward to hearing from you.
Please note that if you prefer to communicate in Dutch just reply to this case in Dutch.
Have a great day,
Kind regards
Joeri
Netgear Level 1 Technical Support
http://support.netgear.com
bryrp
Dec 12, 2017Guide
everyone - please try the following: Advanced -> Setup -> QoS Setup -> and disabling WMM for both 2.4GHz and 5GHz.
hopefully that will cut the crap with the wireless issues.
Criticalpain26
Dec 13, 2017Aspirant
It did not for me :(
I am also having a 5G wifi problem after updating to V1.0.9.14.
Normally around 350MB/s on 5G, and now it looks like its locked on 40MB/s ish.
I'm going back to V1.0.9.12 so see if that works.
- bryrpDec 13, 2017Guide
this is my last netgear product (unforunately). I will also cease to suggest netgear as a router for friends and family (Systems engineer here). For those of you that are tired of the wireless issues please look into flashing DD-WRT or Advanced Tomato firmware. They have a version available for the r7000 router that is far more feature friendly as well as functional at the very basics that should be default for a router.
- tulongDec 15, 2017Guide
I may give this suggestion a try as I am so tired of this freaking router. If after flashing the firmware didn't work, I would go and get a Linksys router as a replacement. I am going to do the same as you said that I will not ever suggest Netgear product to anybody and will advise them to stay away of that brand as a disease.
I look on the site and dd-wrt doesn't have one that supports Netgear R7000 model just yet :-(
However, Advanced Tomato does have the firmware for Netgear R7000 yay.
- HWAMDec 18, 2017Apprentice
Firmware V1.0.9.18_1.2.27 is available now. Who wants to test??
- shamarinDec 18, 2017Virtuoso
Allready update to this one. It's good.
- juchedDec 18, 2017Apprentice
Just updated, will see. First couple speed tests on wired machine are slower... I hope I don't need to "factory reset" and do all my configuration again.
Didn't have any problems with Wi-Fi. With 1.0.9.14 802.11ac for Russian region was fixed (on previous it was available only 600 Mbit speed, now 1300 Mbit as should be).
- PatrickvbDec 18, 2017Tutor
I would like to understand what has been changed or fixed in the latest version before i update. I am on V1.0.9.14_1.2.25 now. Sometimes the wifi speed drops under the 10Mbps but after a reboot of the router it's back at >90 Mbps.
- tulongDec 18, 2017Guide.23 was not great but better. The .25 was horrible. My Wi-Fi just got dropped all the time with 5Ghz channel and the speed was terrible.
- juchedDec 18, 2017ApprenticeSpeeds came back up after 10 minutes. Maybe some sort of update occurring in the background or QoS learning.
I also enabled Circle again and will watch speeds and stability. - juchedDec 19, 2017ApprenticeSo, after running for 8 hours my speeds are back down to around 60Mbps on both wifi and wired with Circle enabled. Seems like the circle issue still isn’t fixed.
- HWAMDec 19, 2017Apprentice
I had to update to 1.0.9.18 an hour ago because also my old firmware version got the same problem again after 36 hours. I thought I had fixed it with an old V1.0.9.6_1.2.19 after flashing via the first FW ever. 3 resets and 3 old FW versions were not enough to make it it stable again.
I do not have the trust 1.0.9.18 is solving the 2.4GHz problem. I guess I have to buy a new router. Downtime is not acceptable anymore.
- SntaCruz83Dec 21, 2017Tutor
Just chiming in to say that I'm done with Netgear. I got this router when it first became available and I paid such a premium I refused to give up on it. I just kept thinking, "the next firmware will do the trick" only to be repeatedly disappointed. I'm going to give dd-wrt or tomato a whirl, but in the end, when the time comes for me to choose a new router or make a recommendation to a friend...never again, Netgear.
- tulongDec 23, 2017Guide
Trying to obtain a RMA to return the router and have been on the phone for more than 21 minutes, even though the prompt was saying that wait time is 5 minutes. I guess, Netgear just let their customers hang dry. Just in case any of Netgear engineer can see this, my case number is 29476358. The router is just 3 months old and the warranty is still good until Sep. 03, 2018. I had to hang up because I had to go some where and couldn't wait any longer.
- aubylifeDec 29, 2017Guide
My router died finally. Without hesitation, just bought a new brand router, bye-bye NETGEAR!
- dkjamesDec 29, 2017TutorLucky! Let us know which router you got and how much better it is than Netgear.
Asus RT-AC 86U or 88U, or RT-AC5300, all are good.
I go with RT-AC5300.
