Pamli's avatar
Pamli
Follower
Apr 24, 2017
Nighthawk R7000 Geust Network IP Addressing
We are using this router with static addressing. We are considering using the guest network, but the guest side would need to use dynamic addressing while maintaining static addressing on the other s...
  • netwrks's avatar
    Apr 24, 2017
     Since the router uses the same subnet for wired and wireless clients, it's about managing your DHCP Pool. Create a DHCP lease pool outside of your static ip addresses. There is no control on how many user's can connect to the Guest network, other than who knows the password. R7000 manual.
