Jeff-In-Chicago
Feb 08, 2023Aspirant
Nighthawk R7000: How to access devices connected to LAN wired ports?
 Hello all,      I have a Nighthawk R7000 / AC1900 WiFi router that I've been using for years. I have a problem and am stuck.     How can I use WiFi clients (laptop, tablet, etc.)  connected  to the R...
michaelkenward
Feb 09, 2023Guru - Experienced User
Jeff-In-Chicago wrote:
- The devices connected to the LAN ports have IP addresses of 10.0.0.1, 10.0.02, and 10.0.03
- The Wifi laptop and tablet are automatically assigned IP addresses by the Nighthawk as 192.168.1.x, etc.
When you see both those IP address ranges on a network it can be a sign that you have two routers in the network. By default Netgear goes for 192.168.1.1. But if it sees something there already it picks 10.0.0.1.
What is the modem/gateway/Optical Network Terminator (ONT) between tour R7000 and the Internet?
Jeff-In-Chicago
Feb 09, 2023Aspirant
 I neglected to mention that the R7000 is not connected to the internet or any other network.
Perhaps I should have asked, "What is the best way to use the Nighthawk to create a private WiFi network that can allow me to use a laptop (via WiFi) to access to four devices connected via the LAN ports?"
The four devices are digital projectors. Each has a self-contained web-based administration interface for configuration, accessible through each unit's Ethernet port.
Does this help? Thank you, Michael!
Jeff
- michaelkenwardFeb 09, 2023Guru - Experienced User
 I neglected to mention that the R7000 is not connected to the internet or any other network. Aha. That rules out anything I can contribute. More of a network management thing than getting Netgear kit to cooperate.
