Tint93
Feb 27, 2017Aspirant
Nighthawk R7000 no WiFi, no connection
Hello everyone, I have a problem with my Nighthawk R7000. When turn the R7000 on it powers on, the amber light becomes white but then the problem starts. I can not het the wifi to work. All the l...
- Feb 27, 2017
For a few days i am struggling with this problem. I bought the router used but could not get it to work. I hit the reset button multiple times to reset the device but no effect.
Today i hold down the resetbutton for a loooong time, the power light started blinking an after that the router worked!!! Apperently i had to hold down the reset button longer in order to reset the router (maybe someone can verify this?).
So the problem is solved!
IrvSP, thank you for your time to try to solve the problem.
IrvSp
Feb 27, 2017Master
Some questions.
What are you using to access the routers homepage on a browser? An IP Address or ROUTERLOGIN.NET?
What is the IP Address of the router?
Is this a NEW setup or something recent that happened to a working R7000?
Is your MODEM bridged?
There is a button on the right that turns OFF WiFi... is that depressed?
- Tint93Feb 27, 2017Aspirant
