Tint93's avatar
Tint93
Nighthawk R7000 no WiFi, no connection
Hello everyone,   I have a problem with my Nighthawk R7000. When turn the R7000 on it powers on, the amber light becomes white but then the problem starts. I can not het the wifi to work. All the l...
  • Tint93's avatar
    Tint93
    Feb 27, 2017
    For a few days i am struggling with this problem. I bought the router used but could not get it to work. I hit the reset button multiple times to reset the device but no effect.
    Today i hold down the resetbutton for a loooong time, the power light started blinking an after that the router worked!!! Apperently i had to hold down the reset button longer in order to reset the router (maybe someone can verify this?).
    So the problem is solved!
    IrvSP, thank you for your time to try to solve the problem.
