discountcoffee
Nov 13, 2023Aspirant
Nighthawk R7000 openvpn Cannot load certificate file client.crt
Hello
I have Nighthawk R7000 running firmware V1.0.11.136_10.2.120 and I was wanting to run a vpn.
I followed the instructions about how to turn on the vpn service and installing openvpn.
When I try to run openvpn I get this error in the log:
2023-11-10 14:19:55 us=703000 MANAGEMENT: Client disconnected
2023-11-10 14:19:55 us=703000 Cannot load certificate file client.crt
2023-11-10 14:19:55 us=703000 Exiting due to fatal error
Now searching here I found that this was a previous issue that was fixed in version 1.0.9.30 but that was back in 2018.
Is there any solution now for the latest firmware?
thanks
discountcoffee wrote:
Hello
Which sort of VPN? One that lets you hide your location as you wander around the Internet? Or one that lets you access your own network when you are out and about?
There have been several recent conversations about openvpn.
Search - NETGEAR Communities – openvpn
Did you check there?
- discountcoffeeAspirant
one that lets me access my own network from a remote location.
- KitsapMaster
discountcoffee wrote:Hello
2023-11-10 14:19:55 us=703000 Exiting due to fatal errorNow searching here I found that this was a previous issue that was fixed in version 1.0.9.30 but that was back in 2018.
thanks
When you run the OpenVPN client software and get these errors, how is your remote device connected to the internet?
What device are you running the OpenVPN client software on?
its a fiber connection on a orbi mesh network and its a windows 11 pc running the latest openvpn software.
the nighthawk has a static ip.
I've tried it on our local network on a windows 10 pc and have the same exact error.
I believe the problem is with the certificate the Nighthawk R7000 is generating.
I can open the cert myself and see that it is not blank and it looks valid.
- KitsapMaster
discountcoffee wrote:its a fiber connection on a orbi mesh network and its a windows 11 pc running the latest openvpn software.
You cannot test an Open VPN connection from the same network where the Open VPN server on the router is connected.
If you have a mobile device, you can disconnect from the local Wi-Fi and test over a cell service connection. With a laptop computer, you will have to connect to the internet from somewhere besides at home where your Open VPN server is connected.
