Tom2B
Jul 16, 2021Guide
Nighthawk R7000 router drops connection to the internet periodically
The router, usuall about once a day, loses connection to the internet. Other devices on the network can see one an other but no internet connection. Power cycling will clear the problem. The cable mo...
Tom2B
Jul 17, 2021Guide
The modem says that it is an R7000 Firmware Version V1.0.10.90_10.2.90 (A check indicates that this is the latest version of the firmware for this device).
All connected devices lose internet connectivity. I can't identify a set of circumstances that seem to cause the problem. There doesn't seem to be a particular time of day.Devices on the network side can see one an other; just no connection to the internet. Computers will say no internet connection or cannot connect to the server at ... . Some wireless devices looking for mail will just spin forever.
antinode
Jul 17, 2021Guru
> The modem [...]
An R7000 is a router, not a modem. Are you using a modem with it?
> [...] says that it is an R7000 Firmware Version V1.0.10.90_10.2.90
https://community.netgear.com/t5/x/x/m-p/1900901#M155834
> this device).
Try a better check?
https://community.netgear.com/t5/x/x/m-p/2069376#M186506
> All connected devices lose internet connectivity. [...]
After you try a less hopeless firmware version, general advice:
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual (at least). Read. Look for the
LED descriptions and "Troubleshoot". Further reading might not hurt,
either.
