blueharleytom
Jun 21, 2017Tutor
NightHawk R7000 Router login page 192.168.1.1 inaccessible
I received an email for the new firmware update so I tried to access the login page at 192.168.1.1 but it times out. This page isn’t working 192.168.1.1 didn’t send any data. ERR_EMPTY_RESPONSE...
- Jun 23, 2017
Well... after rebooting my whole system and tweaking some of my privacy settings (firewall, antivirus) I was able to login to routerlogin.net and get the firmware update and add my other components to the router. I think it's good for now. I lost the original wifi that was set up for me by the GeekSquad but I have new ones from xfinity/Comcast. Thank you for answering my plea for help. I really appreciate it.
Susan (Mrs blueharleytom)
William10a
Jun 22, 2017Master
Have you tried a reset on the router clear the router back too default?
May be some of the old firmware was left behind in the memory.
blueharleytom
Jun 22, 2017Tutor
I did and now I have more issues with all of my connected devices not showing as connected. And I still can not access the router login. I hope this doesn't mean I need to call in the GeekSquad.
Any ideas?
Thank you for trying to help me, I really appreciate it!
- William10aJun 22, 2017Master
Can you get wifi devices to connect too the router if so you may be able access the router's gui .
- blueharleytomJun 23, 2017Tutor
- andrewkhinkleSep 30, 2018Tutor
May be your Router's Default IP Address may not be http://192.168.1.1 , i would suggestion you to check with 10.0.0.1 or 192.168.0.1 !!
