hector1990
Oct 14, 2015Aspirant
NightHawk R7000 Router page inaccessible
Hi, This is a brand new router outta the box! & am not able to login or access the Router's pageon my Desktop! My Default gateway (ipconfig) is 192.168.1.1! steps that I treid 1.) 192.168.1.1 ...
- Oct 15, 2015
try adding routerlogin.net and Gateway IP in trusted zone or sites. So it will never block going forward.
By way did you tried on the new beta firmware , its fast and has few improved features
netwrks
Oct 14, 2015Master
You can't login on to the router? Have you tried to connect to the default SSID and passphrase provided with the router? If you do an ipconfig /all does your laptop or desktop get an IP Address from the router when connecting with an ethernet cable??
The other router is disconnected?
Have you tried clearing your browser's cache?
Have you tried another ethernet port?
