hector1990
Oct 14, 2015Aspirant
NightHawk R7000 Router page inaccessible
Hi, This is a brand new router outta the box! & am not able to login or access the Router's pageon my Desktop! My Default gateway (ipconfig) is 192.168.1.1! steps that I treid 1.) 192.168.1.1 ...
- Oct 15, 2015
try adding routerlogin.net and Gateway IP in trusted zone or sites. So it will never block going forward.
By way did you tried on the new beta firmware , its fast and has few improved features
storm1985
Oct 14, 2015Prodigy
Try disabling any firewall on your Desktop.
If you can access the router on your phone and laptop then definitely not a router issue.
hector1990
Hi, Uninstallating the AnitVirus worekd(Kaspersky Internet Security 2015), now am able to access the router page!
any work around for this?
Thank you very much :)
- mondenathOct 15, 2015Prodigy
- hector1990Oct 15, 2015Aspirant
Hey,
I uninstalled Kaspersky(trail) on Bitdefender now, its not blocking! & am on the factory shipped firmware[V1.0.3.56_1.1.25], will try the recent firmware now :)
just one question... Why would a Antivirus program block a simple router page? I've Kaspersky installed on my brother's laptop & Asus router with 192.168.1.1 works fine!
Thanks for the help!
- JamesGLOct 15, 2015NETGEAR Employee Retired
Hi hector1990,
Welcome to Community!
The Anti-virus might be too strict. It blocks the page as it is not using any certificate since it is only offline or only uses HTTP. This depends on the anti virus on how it sees the page.
JamesGL
Community Team
