Nicce70
May 12, 2017Aspirant
Nighthawk R7000 vpn connected but nothing happens
Hi I can connect to my VPN with my smartphone Android as picture exampel above (its not my phone picture). It sais "connected" and some data bytes in and out is showing. Still I cant connec...
- May 15, 2017
I SOLVED IT!
I'm using the function "Access Control" on my router, and had the "Block all new devices from connecting" on.
When I changed the setting to "Allow all new devices to connect" then the VPN connected smartphone gained access to the LAN and the internet.
May 12, 2017Guru - Experienced User
- Nicce70May 12, 2017Aspirant
I have an Android phone and not a Iphone. So I don't know if that is a solution for me?
- FURRYe38May 12, 2017Guru - Experienced User
Might do a search for vpn on android then:
https://www.netgear.com/search-support.aspx?&q=setup%20vpn%20on%20android
- Nicce70May 13, 2017Aspirant
I have no problem installing and setting this up. It's just not working when I'm done exactelly as Netgear sais. I get connected in the OpenVPN app, but I cant get any contact with LAN or Internet through the VPS connection then in the Android phone, nothing happens, its just waiting.
Anyone else who has any suggestion what is wrong? or having the same experience?
