Nicce70's avatar
Nicce70
Nighthawk R7000 vpn connected but nothing happens
  Hi I can connect to my VPN with my smartphone Android as picture exampel above (its not my phone picture). It sais "connected" and some data bytes in and out is showing. Still I cant connec...
  • Nicce70's avatar
    Nicce70
    May 15, 2017
    I SOLVED IT!
    I'm using the function "Access Control" on my router, and had the "Block all new devices from connecting" on.
    When I changed the setting to "Allow all new devices to connect" then the VPN connected smartphone gained access to the LAN and the internet.
