MRP77
Jan 02, 2016Tutor
Nighthawk R7000 Wi-Fi is OFF (new install)
I had been holding off installing my new Nighthawk R7000 router since you never know what will go wrong... and sure enough, I've got a problem. Basic connection to the internet went smoothly, but...
- Jan 08, 2016
Fortunately I ended up being able to do a straight exchange where I purchased it, even though it had been longer than their normal exchange period.
I plugged the replacement in and after it booted up completely (< 90 seconds) I could connect to the default wireless network without configuring anything on the router.
So if you have this problem like I described in the original post... just exchange it. It's a hardware problem.
netwrks
Jan 02, 2016Master
I would rest to factory one more time with new firmware. If that doesn't work, I would return it..
