MRP77's avatar
MRP77
Tutor
Jan 02, 2016
Nighthawk R7000 Wi-Fi is OFF (new install)
I had been holding off installing my new Nighthawk R7000 router since you never know what will go wrong... and sure enough, I've got a problem.   Basic connection to the internet went smoothly, but...
  • MRP77's avatar
    MRP77
    Jan 08, 2016
    Fortunately I ended up being able to do a straight exchange where I purchased it, even though it had been longer than their normal exchange period.
    I plugged the replacement in and after it booted up completely (< 90 seconds) I could connect to the default wireless network without configuring anything on the router.
    So if you have this problem like I described in the original post... just exchange it. It's a hardware problem.
