Jody_manders
Apr 23, 2023Aspirant
NIGHTHAWK R7000 won’t register
Good evening, I’ve tried contacting netgear about this but still waiting for a response. I bought a nighthawk router used and when I try to go register it, it won’t let me cause it’s been registere...
Jody_manders
Apr 24, 2023Aspirant
Thanks for replying to my post. Yeah I just wanted to register the used router so i can have it integrated into the nighthawk app so I can utilize it.
Kitsap
Apr 24, 2023Master
You can create a Netgear account and you do not have to register the router in order to use the Nighthawk mobile application. Install the mobile application, connect your mobile device to the Wi-Fi, log in to your Netgear account, and within the application you can Add the router in the setup a new device section. The router does not have to be a registered device.
I run a router I bought second hand. I have added it to the mobile application and the device shows up as registered. Most likely by the original owner but not to me or by me. During this process, the mobile application asked me for the Wi-Fi user name (admin) and my Wi-Fi password.
- Jody_mandersApr 24, 2023AspirantThank you, I will have to try this tomorrow and follow up with you!
- michaelkenwardApr 24, 2023Guru - Experienced User
Jody_manders wrote:
Thank you, I will have to try this tomorrow and follow up with you!While Kitsap is correct, you may hit a brick wall if someone has already tied your router to their MyNetgear account so that they can use it with Anywhere Access.
If it doesn't let you tie the router to your MyNetgear account, and you can't get the original owner to release it, you may have to invoke divine intervention in the shape of a Netgear moderator. But you can cross the bridge when you come to it.
- Jody_mandersApr 24, 2023AspirantThank you for your input! Hopefully I will not have to! Lol
