pikman80
Sep 24, 2015Aspirant
Nighthawk R7000 Won't connect
I purchased this router on July 7, 2015. I was able to set it up fine, and it was working perfect. All of a sudden, it stopped work. It won't send out a wifi signal to none of my devices. I am runnin...
- Oct 01, 2015
OMG, that's what the issue was! I was at the computer shop today, and the guy told me to bring it back in, he wanted to check something. I looked at the power plug, and tried one that was the same, and it worked. I feel like a **bleep**. So much frustration. Wish they would have sent those accessories with it. I never would have thought to check that, because it was getting power to it. Thanks for all the help.
pikman80
Sorry. Yes, won't connect to my isp. It was working fine, then all of a sudden, it just stopped.
VE6CGX
Sep 24, 2015Master
Couple things to try:
1. I am sure you reconfigured or restored router configuration from saved one since you
reset the router.
2. Turn of everything, modem, router, your PC - wait for 1 min. or so -them turn on modem,
wait a few seconds for modem to settle down, then turn on our router, wait a few seconds,
then PC.
Problem solved? If not from PC use command ipconfig /all, what do you see? If still no good,
ipconfig /renew, still no good? then ipconfig /flushdns let us know the result.
Good luck.
- pikman80Sep 26, 2015Aspirant
Microsoft Windows [Version 6.3.9600]
(c) 2013 Microsoft Corporation. All rights reserved.
C:\WINDOWS\system32>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : F*****
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : NoC:\WINDOWS\system32>ipconfig /renew
No operation can be performed on Ethernet while it has its media disconnected.Ethernet adapter Ethernet:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller
Physical Address. . . . . . . . . : 6C-62-6D-EC-93-A3
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
C:\WINDOWS\system32>And it flushed the dns fine.
When I connect my old router, it conects no problem.
