pikman80
Sep 24, 2015Aspirant
Nighthawk R7000 Won't connect
I purchased this router on July 7, 2015. I was able to set it up fine, and it was working perfect. All of a sudden, it stopped work. It won't send out a wifi signal to none of my devices. I am runnin...
- Oct 01, 2015
OMG, that's what the issue was! I was at the computer shop today, and the guy told me to bring it back in, he wanted to check something. I looked at the power plug, and tried one that was the same, and it worked. I feel like a **bleep**. So much frustration. Wish they would have sent those accessories with it. I never would have thought to check that, because it was getting power to it. Thanks for all the help.
VE6CGX
Sep 24, 2015Master
Couple things to try:
1. I am sure you reconfigured or restored router configuration from saved one since you
reset the router.
2. Turn of everything, modem, router, your PC - wait for 1 min. or so -them turn on modem,
wait a few seconds for modem to settle down, then turn on our router, wait a few seconds,
then PC.
Problem solved? If not from PC use command ipconfig /all, what do you see? If still no good,
ipconfig /renew, still no good? then ipconfig /flushdns let us know the result.
Good luck.
pikman80
Sep 26, 2015Aspirant
Microsoft Windows [Version 6.3.9600]
(c) 2013 Microsoft Corporation. All rights reserved.
C:\WINDOWS\system32>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : F*****
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
C:\WINDOWS\system32>ipconfig /renew
No operation can be performed on Ethernet while it has its media disconnected.
Ethernet adapter Ethernet:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller
Physical Address. . . . . . . . . : 6C-62-6D-EC-93-A3
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
And it flushed the dns fine.
When I connect my old router, it conects no problem.
