ian22red's avatar
ian22red
Nighthawk R7000 Won't connect
Hi I have just purchased a Netgear R7000 Nighthawk router to use with my home set-up because my existing Netgear router DGND4000 doesn't support Chromecast.  So I though of using the 4000 as the ADS...
  • JamesGL's avatar
    Oct 08, 2015
    Hi ian22red,
    Welcome to Community!
    What is the IP address of the computer when directly connected to the modem? Did you enter the ISP credentials in Internet setup option of the R7000? What is the firmware version of the router?
    JamesGL
    Community Team
