Luc1d_catto's avatar
Luc1d_catto
Follower
Nov 17, 2024
Nighthawk R7000P won’t connect to the app or webpage can’t setup router router not found
I can’t see what firmware it’s on Netgear won’t replace it all leds are while but I can’t set it up on the mobile app or access it on the webpage
1 Reply
  • michaelkenward's avatar
    michaelkenward
    If there is one it might help if you told people the make and model number of the modem/gateway/ONT that connects this router to the Internet. Is it, by any chance, also a router, with a set of LAN ports on the back?
    I ask because a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
    Just another user with time on their hands.
