dbl42's avatar
dbl42
Follower
Jul 29, 2022
Nighthawk R7350 VPN Service
I have a subscription to IPVanish. Can I install IPVanish on the R7350 router, so I don't have to install the app on every device connected to the router, which is not possible for at least one of my smart TVs?
  • There is two parts to that puzzle.  One is how to put the third party firmware on the router and the second part is how to remove it and put  Netgear OEM firmware back on!
    • Kitsap's avatar
      Kitsap
      Master
