buzbard
Aug 03, 2022Tutor
Nighthawk R7450 Lost local network after firmware update
After updating my router's firmware to V1.2.0.92_1.0.1, I have lost all local network connections.
I have 4 Windows 10Pro PC's connected, they all still have internet access, but are not able to see each other on the local network.
I have a USB3 HDD connected to the router and the Media Server still works for BlueRay/DVD players, but I cannot connect to the Readyshare drive with any PC to access the files, I have to physically remove the drive from the router and connect it to a PC to access the files.
In the PCs I have "SMB 1.0/CIFS Client" turned on, but turning it off doesn't help.
I have factory reset the router, it did not help.
Everything worked fine before the firmware update.
Anything else I should try?
Thanks
buzbard wrote:
Yes network is still set to private.
Tried the network troubleshooter in Windows?
It used to be a joke but has been getting better/
Have you tried typing the device addresses into Windows Explorer?
Devices have a habit of going AWOL. They suddenly sprint into view if I do that. One reason why I keep shortcuts to the rest of the network, PCs and NAS stuff.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.- buzbardTutor
Just tried all that again with no luck.
Disconnected power to both modem and router, and waited 5 minutes.
I powered up the modem and waited for the internet connection (about 3 minutes), then I connected power to the router and powered it up.
I then waited another 5 minutes before checking network connections.
When I open Windows Explorer and click Network, I can see the PC that I'm currently on plus the R7450 (Gateway), modem "ZyXEL APS" and printer (Brother HL-L2360D series) and that's all.
Did you check on the windows pc's to see if they'd changed their network connections from private to public?
It could be it thought the router was a new network after the firmware upgrade and when set to public, isn't able to see the shared drives/computers.
- buzbardTutor
