Powersurge
Jan 03, 2017Aspirant
Nighthawk r7800 Unable to acces login page
I upgraded my router from wndr3700 to the nighthawk r7800!! Yay I was so happy!! BUT pff the darn thing is giving me ALOT of work. My problem is that I'm unable to connect to the login page (...
- Jan 10, 2017
Hi Powersurge,
Check this KB article and see if it helps.
http://kb.netgear.com/30012/Unable-to-access-router-management-page-with-Kaspersky-installed
Powersurge
After I setup through my mobile.. I can access internet without a problem. Only it wont let me connect to 192.168.1.1 (PC-LAN)
Jan 03, 2017Guru - Experienced User
Ok. Are you able to ping 192.168.1.1?
Does the PC have a static IP address or is it using DHCP?
