Powersurge
Jan 03, 2017Aspirant
Nighthawk r7800 Unable to acces login page
I upgraded my router from wndr3700 to the nighthawk r7800!! Yay I was so happy!! BUT pff the darn thing is giving me ALOT of work. My problem is that I'm unable to connect to the login page (...
- Jan 10, 2017
Hi Powersurge,
Check this KB article and see if it helps.
http://kb.netgear.com/30012/Unable-to-access-router-management-page-with-Kaspersky-installed
Powersurge
Yes. I'm able to ping 192.168.1.1 without packet loss.
PC is using an assigned ip address from DHCP.
Everything seems in order my pc ip address is 192.168.1.2, subnetmask 255.255.255.0 and gateway 192.168.1.1
Jan 04, 2017Guru - Experienced User
Did you try more than one browser? Which one(s) did you try?
