Kilr0y
Apr 15, 2018Aspirant
Nighthawk R7800 VoIP setup
So. I wanna connect my ip phone through my router and from my understanding this should be possible with this router but i cant seem to find anything relevant on how to setup it up. Anyone have some...
- Apr 16, 2018
Kilr0y wrote:So if i were to get the "Gigaset C530 IP" would that work my router,
or would it be possible to plug it directly into the fiber box on the wall?
Same as the ATA-like VoIP device we talked of before.
As I said, you might have to disable the SIP ALG on the router if your VoIP provider does has deployed some advanced NAT handling capabilities.
Most ISP only assign you a single IP address on a home/consumer/SOHO Internet connection - plugging multiple devices direct to the "WAN" or Internet port will lead to problems - so this is in general a no-no.
Kilr0y
Apr 16, 2018Aspirant
Thanks for the reply. So if i were to get the "Gigaset C530 IP" would that work my router, or would it be possible to plug it directly into the fiber box on the wall?
schumaku
Apr 16, 2018Guru - Experienced User
