sharonb10's avatar
sharonb10
Nighthawk R7800
I was trying to update the firmware for my router but kept getting a couldn't connect to the internet error so did a hard reset but now Netgear is showing as wifi but not connecting to the internet at all.
Any suggestions please?
  • michaelkenward's avatar
    michaelkenward
    That's a bit thin on useful details.
    What modem/gateway/ONT sits between the R7800 and the Internet?
    What is "showing as wifi but not connecting to the internet".
    To update the firmware start here:
    How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
    • sharonb10's avatar
      sharonb10
      Thank you
      There's only a Foxtel box and the Nighthawk router.
      All our devices are showing as ' connected without internet'
      I will try the link you provided.
        michaelkenward
        What is that Foxtel box? What is that Netgear router?
        Model numbers?
        What are these devices? How are they connected? Wired> WiFi?
        Where they say " connected without internet"?
