Va_tech90's avatar
Va_tech90
Nighthawk R7900P X6S setup issues
I have been trying to set up my R7900P WiFi router all afternoon and each time I get to the point where it says it’s configured and I click “Next”, it idles for about a minute or two then says it encountered a problem and to try again. I’ve hit try again several times and it does it each time. I’ve also gone through the setup process at least 4 times and this last step is where it hangs up.
It shows my WiFi is connected; however, I cannot log into my Nighthawk app or www.routerlogin.net. I can’t access my email, it won’t let my husband connect his x-box to the WiFi and some internet sites won’t connect.
And while I’m here, is there a way to designate the guest WiFi as the 2.4 ghz and the main WiFi as the 5.0 ghz so we can switch between the two or use one or the other for different devices?
  • michaelkenward's avatar
    michaelkenward
    What firmware version do you have on the device?
    A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
    It might also help if you told people what the modem is in front of this router, if there is one. The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
    The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
    Having two routers on a network can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
    This explains some of the other drawbacks.
    What is Double NAT? | Answer | NETGEAR Support
    Apologies for all the questions. But you can help people to help you by providing the information suggested in this forum's header:
    Subject (Include model number and brief summary)
    Model (Recommended - Helps the community give the best answers)
    Body (Include additional detail including model version, firmware, OS and environment where relevant.)
    They are there for a good reason.
    • Va_tech90's avatar
      Va_tech90
      I’m sorry, I read in the header that we should give the model number and describe what issues we were having. I must have missed the part about what firmware version I have, which modem I’m using and from which university I received my masters in Internet Technology.
      Excuse me for the sarcasm; however, I thought this forum was to help people. I’m not an idiot, I have a degree in engineering and I’ve worked in that field for over 25 years. Not everyone knows the latest and greatest in the tech field, but if you’d like to discuss something I’m an expert in then please feel free to point out my weaknesses!
      That being said, having just purchased this router I downloaded the “latest” firmware ver 1.4.1.68.
      I am using an Arris Surfboard SB6190 modem that does NOT have a router.
      If you need more information please just ask. The “tone” of the help on this forum is quite condescending. I understand that there may be a LOT of tedious and repetitive questions, but directing that frustration at a new forum user is not necessary.
        michaelkenward
        Va_tech90 wrote:
        II must have missed the part about what firmware version I have, which modem I’m using and from which university I received my masters in Internet Technology.
        Oh dear. One of them. You have my sympathies.
        You clearly didn't read the page where you entered your message.
        * Body (Include additional detail including model version, firmware, OS and environment where relevant.)
        Plain vanilla modem.
        I'd better not. It might upset you to ask more questions. Best if someone else chips in. I'll leave it at this.
        Visit the support pages:
        Support | NETGEAR
        Feed in your model number and check the documentation for your hardware.
        You may have done that already. I can't tell from your messages.
        I mention it because Netgear gave up on supplying paper manuals years ago and people sometimes miss the downloads.
