npinks
Oct 19, 2017Tutor
Nighthawk R8000 to Virgin Media HUb
Tomorrow, i'm switching from BT to Virgin Media, so will be getting their superHub and i want to keep using the NightHawk X6 as my wifi, as the range is loads better and everything (inc my Arlo) conn...
- Oct 30, 2017Hi All
Sorry for the late reply back, I managed to fully reset the X6 and upon rebooting it up, the router went through a new install and started working, with the CAT5e cable I had. Then a straight swap over to the CAT6 the following morning
All sorted and runs perfect
npinks
Oct 20, 2017Tutor
so i have got my Virgin Hub3 installed today. Connected the Hub to the NightHawk via ethernet cable to the Yellow Socket on the back and rebooted the NH and the Virgin Hub placed in to Modem Mode, but still got no internet connection from the NH
Tried different cables (Cat 5a & e? ) and still no joy
Any advice, really don't want to lose the use of the NightHawk
- JamesGLOct 24, 2017NETGEAR Employee Retired
Hi npinks,
Can you go online when computer is connected to the Virgin Media Hub? If yes, try the article below.
https://kb.netgear.com/1086/No-Internet-with-new-router-MAC-spoofing
- JamesGLOct 29, 2017NETGEAR Employee Retired
Hi npinks,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
- npinksOct 30, 2017TutorHi All
