npinks
Oct 19, 2017Tutor
Nighthawk R8000 to Virgin Media HUb
Tomorrow, i'm switching from BT to Virgin Media, so will be getting their superHub and i want to keep using the NightHawk X6 as my wifi, as the range is loads better and everything (inc my Arlo) conn...
- Oct 30, 2017Hi All
Sorry for the late reply back, I managed to fully reset the X6 and upon rebooting it up, the router went through a new install and started working, with the CAT5e cable I had. Then a straight swap over to the CAT6 the following morning
All sorted and runs perfect
JamesGL
Oct 24, 2017NETGEAR Employee Retired
Hi npinks,
Can you go online when computer is connected to the Virgin Media Hub? If yes, try the article below.
https://kb.netgear.com/1086/No-Internet-with-new-router-MAC-spoofing
JamesGL
Oct 29, 2017NETGEAR Employee Retired
Hi npinks,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
- npinksOct 30, 2017TutorHi All
All sorted and runs perfect- JamesGLOct 30, 2017NETGEAR Employee Retired
Hi npinks,
I am glad to know it works now.
