stedgar's avatar
stedgar
Nighthawk R8000P NTP Server
I have  a Netgear Nighthawk R8000P Router with Firmware Version V1.4.3.88_1.3.50.
I am unable to adjust the NTP settings.  Keeps defaulting to International Date Line West.
I have pinged time.google.com and i get the results so the port is open.
Any suggestions to fix this?
  • FURRYe38's avatar
    What browswer are you using to log into the routers web page? Same thing happen with MS Edge or Firefox?
    • stedgar's avatar
      stedgar
      Hello.  I am using both Edge and Chrome.  Neither one will permit me to change the NTP setting or server location.
      I am using Frontier Fiber and their modem is locked in a box in the garage.  Please note that I have never had a problem with this before.  I have even unplugged  their modem to reset it.
      Long story short, I was experiencing lagging delays and slow internet speeds. So I went ahead and did a complete reset of my Netgear router and was able to set everything up like I had before with the exception of the NTP issue.  That is the only issue now is to set the NTP.
      Thank you.
      • FURRYe38's avatar
        You happen to try a factory reset and setup from scratch and try changing the NTP value with the router disconnected from the ONT?
