Evicmar
Mar 10, 2021Guide
Nighthawk R8500 guest network seeing devices when disabled
In the guest network section, "Allow guests to see each other and access my local network" is not selected and my work laptop can see devices on my home network. I'm on firmwware V1.0.2.144. I've tried enabling and disabling it, the guest network, and tried disable/create new name. No matter what I try, I can still see devices on my network. Any thoughts on how to solve this?
Thanks in advance.
> [...] my work laptop can see devices on my home network. [...]
Your (unspecified) "my work laptop" is connected to the R8500 using a
"Guest Network" SSID?"see" _how_, exactly? As usual, showing actual actions (commands)
with their actual results (error messages, LED indicators, ...) can be
more helpful than vague descriptions or interpretations.> [...] No matter what I try, [...]
Think, for a moment, about how little useful information that
non-description conveys to the non-psychics in your audience.> [...] Any thoughts on how to solve this?
Depends on what you wish to "solve". Is your complaint that
something like "ping" works between guest and non-guest devices, or that
some actual data-carrying service, like, say, file sharing, works
between guest and non-guest devices?
On these routers, a "guest network" is not a separate network, but
there are firewall-like rules (enabled by default) which can limit the
ability of "guest" client devices to communicate with non-guest client
devices. If you expect absolutely no communication between guest and
non-guest devices, then prepare for disappointment.- EvicmarGuide
I'm connecting to the wifi network through my laptop's gui. By I can access everything on my non-guest network. I'm able to print to my printer, access and use my Plex server, output my audio to my AppleTV, etc. NOTHING is blocked at all. I'm able to ssh to a linux host not in the guest network from the guest network. There are no rules allowing NAT or Port forwarding on the router. UPnP is disabled.
> I'm connecting to the wifi network through my laptop's gui. [...]
> "Guest Network" SSID?See the difference?
