phillipg
Dec 03, 2016Tutor
Nighthawk R8500 replacement?
Hi, I just had a bad experience with a new R8500. Worked fine intially, and 48 hours later it was a brick. Seems to be the same bootloop issues that other people have had. I bought this as I needed t...
- Dec 07, 2016
In the end, I exchanged the router through Amazon. ElaineM was very helpful here in the forums, but customer service was not getting back to me. I was tired of waiting for someone to send me a return authorization, and in the end, it was easy to just exchange the router through Amazon. Hopefully the new R8500 will not have the boot issue. If it does have issues, I will post an update.
microchip8
Dec 04, 2016Master
Have you considered to RMA the product? The R8500 is decent hardware but it looks like you guys got bad apples
phillipg
Dec 05, 2016Tutor
I'm hesitant to do so with so many people saying they had a problem with their second, replacement R8500. I might just get an extender for my current router, and wait a year or so for the Orbi (and other similiar solutions) to mature.
- ElaineMDec 05, 2016NETGEAR Employee Retired
phillipg I suggest that you contact support and submit a case.
- phillipgDec 06, 2016Tutor
Is the correct contact [email protected]? I've emailed them but have not gotten a response.
- ElaineMDec 06, 2016NETGEAR Employee Retired
Submit a case through my.netgear.com
