phillipg's avatar
Dec 03, 2016
Nighthawk R8500 replacement?
Hi, I just had a bad experience with a new R8500. Worked fine intially, and 48 hours later it was a brick. Seems to be the same bootloop issues that other people have had. I bought this as I needed t...
  • phillipg's avatar
    phillipg
    Dec 07, 2016
    In the end, I exchanged the router through Amazon. ElaineM was very helpful here in the forums, but customer service was not getting back to me. I was tired of waiting for someone to send me a return authorization, and in the end, it was easy to just exchange the router through Amazon. Hopefully the new R8500 will not have the boot issue. If it does have issues, I will post an update.
