MWiggins's avatar
Jun 02, 2016
NightHawk R8500 Shutdown - Overheating?
Noticed this afternoon that my R8500 was off. I thought that the power strip had failed so I moved the router's power adapter directly to the wall and it powered back up. After an hour or so, I came ...
  • MWiggins's avatar
    MWiggins
    Jun 03, 2016
    Thanks for the assistance, but I contacted Netgear support this morning. They issued an RMA for an overheating unit.
    I came here looking to see if others had experienced this issue. At least now I suppose this thread can serve as reference for anyone else that may encounter it.
