MWiggins
Jun 02, 2016Tutor
NightHawk R8500 Shutdown - Overheating?
Noticed this afternoon that my R8500 was off. I thought that the power strip had failed so I moved the router's power adapter directly to the wall and it powered back up. After an hour or so, I came ...
- Jun 03, 2016
Thanks for the assistance, but I contacted Netgear support this morning. They issued an RMA for an overheating unit.
I came here looking to see if others had experienced this issue. At least now I suppose this thread can serve as reference for anyone else that may encounter it.
MWiggins
Jun 03, 2016Tutor
Update
Router continued to fail in less than an hour under normal household usage conditions. Hooked up old router and left it running all night with no issues. R8500 sat powered on with no network activity and still had power this morning. Not warm to the touch. Seems to definitely be an overheating issue.
VE6CGX
Jun 03, 2016Master
I think either it is over heating or flaky wall wart issue. Some times during assembly they don't use enough heat sinking compund
or heat sink itself is loose.
