jdwerosa21
Oct 20, 2016Aspirant
nighthawk R8500
Do not buy the Nighthawk R8500 router. It does not live up to it's expectations of covering 4,000 feet. It will not even give a good signal at 30 feet with only half walls and hallways. It was the mo...
- Oct 22, 2016
Thaks for your response. I definitely agree now that one unti will not cover 4,000 square feet. Netgear should re think their marketing and what they present on their packaging. I paid over $400 and I would have expected much better performance. I have added a Netgear Acess Point WNDPA620 and two Linksys R6500 extenders and I now have a somewhat adequate coverage at a very high expense. I hope the new Orbi's or google routers coming out change WIFI coverage.
Retired_Member
Oct 22, 2016The orbi uses wifi between the base and satellite So it would seem it's a glorified range extender?
jdwerosa21
Oct 22, 2016Aspirant
I do like the fact that it has the same SSID and a separate 3rd band that does not carry any traffic but allegedly just maintains the signal.
