markmnh
Feb 02, 2021Aspirant
Nighthawk Router AC1750 keeps dropping out.
Greetings,
I have had this router for one and a half years. Recently it started to drop out several times a day. I am not aware of any changes withihn my network. Any suggestions?
AC1750 is a speed, not a model.
What actual router do you have?
what modem/gateway is it connected to?
What firmware is on it?
Is it all devices dropping, just wireless? Whats exactly happening?
- markmnhAspirant
Hi, Thanks for trying to help me out. The Router is a RC6700v3 with the moist recent firmware. It is connected to a Spectrum Modem.
I notice that I have lost the WIFI signal to the TV or other device. I run into the office where the router is located. Depending on how quick I am I find the router power light orange or white. With all other lights out. Typically it will restore itself in a few minutes. When it comes back up I get the 2.4 and 5 GHz lights pretty quick but it takes a bit longer to get the internet light back up. This is most likely to occur late afternoon and into the evening. The symptoms are typical of performance after a power outage or reboot. I replaced the power supply yesterday but it just happened again. This time it took longer to get the white power light back on and a good five minutes to get the internet light back up. The internet provider tells me that the incoming cable is fine.Thanks,Mark Murray- michaelkenwardGuru - Experienced User
I assume that you mean R6700v3
Does that Spectrum Modem have a make and model? It could be the all important missing detail. That's why we always ask about it.
markmnh wrote:
Depending on how quick I am I find the router power light orange or white. With all other lights out.Orange or white? I see no "orange" option.
If the Internet LED is off, that explains why the wifi went down. Your Internet connection died. But the wifi LED should stay on.
Could be a hardware failure.
What do the router's logs show?
