tequekama
Dec 29, 2023Aspirant
Nighthawk Router Giving 400 Bad Request
Hi, I upgraded the firmware and thought nothing of it. A few weeks later I tried to login from a computer hardwired connected to the router and received first an ad for the Nighthawk App, and a link to use if you did not want to use the app. I followed the link and received a 400 error Bad Request. I then tried to use the app and it didn’t accept my password. I have tried 3 different browsers from the hardwired computer, all giving the same 400 error. Any suggestions?
1 Reply
Did you reset the router to factory settings after the firmware flash?
New firmware sometimes introduces changes that are not compatible with the old configuration. So a factory reset is the first thing to try if you have problems with new firmware.
What NG router model do you have?
