baniskher's avatar
baniskher
Follower
Apr 26, 2022
Nighthawk router won’t connect to Internet
  • The router is connected to a Netgear cable modem.
  • It was activated by Xfinity.
  • iPhones can see the router networks, but can’t dee the Web.
Any tips on troubleshooting?
Equipment:
Netgear CM1000v2 Cable Modem Netgear R6700v3 AC1750 Smart WIFI Router.
1 Reply
  • plemans's avatar
    power off the modem and the router and disconnect the coax from the modem. Make sure everything is disconnected from the router.
    Leave it off for 2 minutes.
    then connect the coax back to the modem and power it on.
    Wait 2 minutes.
    Connect the modem to the wan port on the router.
    Power the router on. Give it 2 minutes.
    Attempt setup on the router.
    What firmware is on the router?
    Do wired devices work?
