ClaveMan's avatar
ClaveMan
Nighthawk S8000 Switch Reports Getting "100MB Full" Speed. Gigabit Switch?
My new Nighthawk S8000 (GS808E) switch is proudly reporting all ports are running "100MB Full".  Where is the Gigabit performance I paid for?  Is there a setting I am missing in the config web server...
  • ClaveMan's avatar
    Jul 31, 2017
    The answer to my question, paraphrased here..
    "On my switch admin page, why don't I see an option to set the port speeds to Gigabit?  Why only 100MB?  I can't believe I bought a door stop 100MB switch for $99").
    Turns out this is a NETGEAR FAQ.  No worries..
    Apparently the setup doesn't acknowledge the switch is Gigabit anywhere.
    You have the option to set your port speed to one of these:
    1. Auto
    2. Disable
    3. 10M half
    4. 10M full
    5. 100M half
    6. 100M full
    Gigabit shows up when it wants to show up.
    As the article below states -- if you set the port to "Auto" your router will attempt to connect at 1000Mbps (Gigabit).
    So.. I took another look.  Sure enough..  on the switch admin home page under "PORT STATUS", it shows for port 1 (Gaming)
    "Linked Speed= 1000M full"
    So all is well.. (just make sure you have at least Cat5E)
    How do I change the speed and duplex mode of a port on my GS808E Nighthawk S8000 Gaming & Streaming Switch?
