djahn28
Feb 09, 2017Aspirant
Nighthawk X10 10gb connection
hello ! i was wondering if i run a SFP+ cable from my computer to the nighthawk x10 will i be able to access the internet though it? as well as access my usb drive? any help would be great !!!! than...
- Feb 10, 2017
djahn28 wrote:
I don't plan to nor am I trying to get 10 gigabytes over the internet I just want to be able to have the best connection to my USB storage device as well as have a connection to the internet. When I'm transferring 10 or 12 movies from my main Drive to my USB external drive that's connected via USB 3.0 I'm only getting about 50 or 60 megabytes per second transfer rate from my main computer to the drive with the 10 gigabit connection I should be able to maximize the USB 3.0 skip abilities with the way my way to set up and guess between 120 and 240 megabytes per second give or take.FWIW, smallnetbuilder.com was only able to get 103.7 megabytes per second out of the USB 3.0 port (link). Even a Gigabit port can handle that.
djahn28
Ive ordered everything including the sfp+ card and cables . just waiting in amazon to get it here
William10a
Feb 09, 2017Master
10giga to every wired device would the best thing to have no band witdh problems and fastest internet to your computers too. There is youtube video a 10giga networks install if iterested.
