djahn28
Feb 09, 2017Aspirant
Nighthawk X10 10gb connection
hello ! i was wondering if i run a SFP+ cable from my computer to the nighthawk x10 will i be able to access the internet though it? as well as access my usb drive? any help would be great !!!! than...
- Feb 10, 2017
djahn28 wrote:
I don't plan to nor am I trying to get 10 gigabytes over the internet I just want to be able to have the best connection to my USB storage device as well as have a connection to the internet. When I'm transferring 10 or 12 movies from my main Drive to my USB external drive that's connected via USB 3.0 I'm only getting about 50 or 60 megabytes per second transfer rate from my main computer to the drive with the 10 gigabit connection I should be able to maximize the USB 3.0 skip abilities with the way my way to set up and guess between 120 and 240 megabytes per second give or take.FWIW, smallnetbuilder.com was only able to get 103.7 megabytes per second out of the USB 3.0 port (link). Even a Gigabit port can handle that.
djahn28
Feb 10, 2017Aspirant
- TheEtherFeb 10, 2017Guru
- schumakuFeb 11, 2017Guru - Experienced User
TheEther wrote:
One limiting factor is the non-native NTFS implementation, convinced an R9000 supported native Linux file system would perform better.
Reasons to deploy 10 GbE - with a single SFP+ port here is of course not the plain end-to-end blinding marketing numbers - much more it should allow to use multiple services concurrently without a bandwidth limitation, being connections to R9000 services like USB device sharing, Plex, Internet, trunked and sinlge GbE access for a single direct connected system, or for multiple in combination with a 1/10 GbE switch offering an SFP+ uplink. Not that easy to understand for many in this consumer class marketing environment.
Curious on how many R9000 owners are really making use of the 802.11d (60 GHz WiGig) taking a lot of room and ading marketing numbers again. Bet there would be even less response than on SFP+/10GbE forum questions.- William10aFeb 11, 2017Master
I believe that probably the first time Internet over tv cable in fact tv cable started from a man tying to keep his wife happy and he placed a antenna and amplifier that he made on top of the highest building in town all just to receive one station and dsl for the phone people had the same type discussions about would it ever take off or just become a passing thing. The 10 giga may not find it's main use in the home but should fine a strong foot hold in the business world.
