djahn28
Feb 09, 2017Aspirant
Nighthawk X10 10gb connection
hello ! i was wondering if i run a SFP+ cable from my computer to the nighthawk x10 will i be able to access the internet though it? as well as access my usb drive? any help would be great !!!! than...
- Feb 10, 2017
djahn28 wrote:
I don't plan to nor am I trying to get 10 gigabytes over the internet I just want to be able to have the best connection to my USB storage device as well as have a connection to the internet. When I'm transferring 10 or 12 movies from my main Drive to my USB external drive that's connected via USB 3.0 I'm only getting about 50 or 60 megabytes per second transfer rate from my main computer to the drive with the 10 gigabit connection I should be able to maximize the USB 3.0 skip abilities with the way my way to set up and guess between 120 and 240 megabytes per second give or take.FWIW, smallnetbuilder.com was only able to get 103.7 megabytes per second out of the USB 3.0 port (link). Even a Gigabit port can handle that.
djahn28
Feb 10, 2017Aspirant
Awesome!!!! Ive been getting so many "i dont knows" it was crazy . thanks for the help
schumaku
Feb 10, 2017Guru - Experienced User
To add a little bit of insight ... all ports, being the SFP+ (10 GbE), the single GbE ports on the switch, and the optionally trunked (GbE switch port 1&2) interfaces, and last but not least the 2.4/5/60 GHz primary SSIDs are all connecting into the same broadcast domain, the same TCP/IP subnet.
- William10aFeb 10, 2017Master
I remember when the cell phone came in a bag and was analog not todays digital phones that fit in your packet I see a point in time where like the cellphone started as toy for some became needed for eveyday life and the must used iteam today. The 10gigabit internet true today 10giga internet is not needed by every one today but give it say seven to ten years time life with out will be impossible. Remember the Raytheon radar oven that needed water running thought it to cool a radar tube today it is your micro wave oven that you use to cook or warm food in.
