djahn28
Feb 09, 2017Aspirant
Nighthawk X10 10gb connection
hello ! i was wondering if i run a SFP+ cable from my computer to the nighthawk x10 will i be able to access the internet though it? as well as access my usb drive? any help would be great !!!! than...
- Feb 10, 2017
djahn28 wrote:
I don't plan to nor am I trying to get 10 gigabytes over the internet I just want to be able to have the best connection to my USB storage device as well as have a connection to the internet. When I'm transferring 10 or 12 movies from my main Drive to my USB external drive that's connected via USB 3.0 I'm only getting about 50 or 60 megabytes per second transfer rate from my main computer to the drive with the 10 gigabit connection I should be able to maximize the USB 3.0 skip abilities with the way my way to set up and guess between 120 and 240 megabytes per second give or take.FWIW, smallnetbuilder.com was only able to get 103.7 megabytes per second out of the USB 3.0 port (link). Even a Gigabit port can handle that.
schumaku
Feb 12, 2017Guru - Experienced User
While perfectly workable, I don't see the XS708Ev2/XS716 as a complimentary switch - wrong format, fan, not sexy, ... - to match the R9000.
Prices for Gigabit interfaces and per switch port were much higher at the same technology life cycle. And it is not that long ago, that consumer routers came with Fast Ethernet only. Gigabit prices have collapsed - when we see low cost GbE interfaces or "dumb" five/eight port switches for a hand full of Dollars - this can't be a healthy development. And this crash has created most of the price gap.
