Hankhalljr
Jul 07, 2017Aspirant
Nighthawk X10 AD7200 r9000 60GHz 802.11ad WiFi Disable
Hello,
How do I enable the 60GHz 802.11ad WiFi? Router Firmware Version V1.0.2.32. When I login to the router, wireless settings is disable (red X). Please help/advise.
Problem resolved, I was successfully able to disable and enable 802.11ad WiFi.
- JamesGLNETGEAR Employee Retired
Hi Hankhalljr,
Check wireless settings under advanced tab. Make sure "Enable wireless router radio" is checked.
Hi Hankhalljr,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
- HankhalljrAspirant
