dd65
Aug 11, 2022Aspirant
Nighthawk X10 Smart WiFi Router (R9000)
I have had this router for 5 years and it is 5 STAR. I use it connected to a 10G switch through the 10G SPF+ port for 2 NAS Synology Media Servers but, How long before Netgear makes a replacement for...
Aug 12, 2022Guru - Experienced User
Ya I have a ASUS GT-AX11000. Thought its WiFi 6 it does have a 2.5Gb port. ALL the other LAN ports are 1Gb. Had it for a couple of years. It's out dated. Over time the the 16000 will be out dated as well. WiFi 7 is now on the plate. 😉
Hopefully you'll find what your looking for. Still doesn't mean NG is going backwards, rather NG may be putting something out at some future date and it's not keeping up to your wants and needs. So there, you'll have to find something else. Ya we hope NG will come up with some something. However I believe NG has more important things to work on. IMO.
Good luck.
